S32K344 and DEVKIT-MOTORGD
693 次查看
Albatros
Currently, I have S32K3X4EVB-Q172 and I want to use this evaluation board with DEVKIT - MOTORGD. Can I use them together?
656 次查看
petervlna
yes, you can use them together.
You will most probably need to replace some resistors (this is done normally in NXP fab for motor-GD kit)
Please refer to user guide:
https://www.nxp.com/docs/en/quick-reference-guide/DEVKIT-MOTORGD_QSG.pdf
Peter
4 回复数
657 次查看
petervlna
Peter
646 次查看
Albatros
Thank you for your answer, may I ask if there is a way for me to learn which resistors to change?
633 次查看
petervlna
I assume you have following board:
https://www.nxp.com/design/development-boards/automotive-development-platforms/s32k-mcu-platforms/s3...
Schematic rev A
we recommend solder R255, R257, R2184
and unsolder R40, R37, R91, R96
best regards,
Peter
631 次查看
Albatros
Thanks for your answer
