Is it really possible to use at the same time both QSPI and RMII interfaces on S32K344 MQFP172?
According to S32K3X4EVB-Q172 schematics/notes the answer seems to be yes.
But, checking the IOMUX spreadsheet, this part seems to lack of medium or fast pads and/or having a bad multiplexing: after selecting the fixed alternatives needed for the 6 QSPI signals, the RMII outputs TXEN, TXD1:0 can be only mapped to 25 MHz max standard-plus pads.
Any suggestion on what is wrong?
解決済! 解決策の投稿を見る。
Hi Marco,
here is the response:
"The S32K344EVB-Q172 was developed to support most of the functionalities of the MCU, on this time the Ethernet has routed the recommendation on the RM to support QSPI + MII. As you mentioned due to the pad type support RMII + QPSI is not possible for S32K344 devices."
Lukas
Hi Marco,
Lukas
Is this still the case, has silicon been improved?
Hi Marco,
let me check this. I will let you know the result later.
Lukas
