S32K344 LPSPI DUAL CLOCK MODE
MyLV
Hi NXP team,
I want to reduce Spi_AsyncTransmit() consumption on S32K344.
when I changed Core_LCK down to 80Mhz and the Spi_AsyncTransmit() executed time is 104 μs in result. if Core_LCK is 160Mhz then executed time is 52 μs.
According to RM, S32K344 support to 160Mhz in maximum.
any suggestion to have done thru SPI configuration please?
When I check on Lpspi_Ip_Cfg.h file there is LPSPI_IP_DUAL_CLOCK_MODE ( Dual clock configuration). I confused about it.
Could you explain?
@cuongnguyenphu
MyLV
Hi @cuongnguyenphu
Thank you for replying.
I want to reduce Spi_AsyncTransmit() executing time. It seem only Core_LCK (MCU configuration) impact on the processing time.
Is there any solution to reduce the Spi_AsyncTransmit() executing time through SPI configuration?
Related to Clock, LPSPI_IP_DUAL_CLOCK_MODE is available inside SPI configuration.
From my understanding, the LPSPI_IP_DUAL_CLOCK_MODE allows user to change the clock mode at runtime, but it only effects the SPI data exchange rate, NOT the execution time of Spi_AsyncTransmit() right?
MyLV
cuongnguyenphu
Hi @MyLV ,
Yes you're right, the setting LPSPI DUAL CLOCK MODE only effects to SPI data exchange rate.
To change Core_clk in runtime you should do as following:
1. Config 2 Mcu Clock setting mode, let's say: Clock Setting 0 for Core_Clk 80Mhz, and Clock Setting 1 for Core_Clk 160Mhz.
In S32CT, you can do this by below steps:
- In Clock tool, create 2 functional groups:
- Config Core_Clk for each Functional group
2. In Peripheral Tool, in MCU module, create 2 MCU Clock setting config coresponds to 2 Functional group of Clock tool in step1:
- Generate code.
3. In run-time, whenever you want to change the clock setting, just call  Mcu_InitClock(<param>) with <Param> is the ID of MCU clock setting, which is generated in Mcu_Cfg.h file
cuongnguyenphu
Can you explan your question in more detail please? I cannot understand your question
