S32K344-EVB test terminal
462件の閲覧回数
Simon-Liu
Contributor V
Hello
I am using the S32K344 EVB hardware and want to test the sleep wake-up function. I use the edge trigger of a terminal as the wake-up source, so I need a TP point of a terminal for external high level access. Is there a TP point of the terminal on the EVB board?
BestRegards,
Simon
436件の閲覧回数
Simon-Liu
Contributor V
Hi @Senlent
我使用的是黑色的EVB板,并且之前没有硬件说明资料,现在已经找到了说明资料,可以找到Pin对应的点位了。
2 返答(返信)
441件の閲覧回数
Senlent
Hi@Simon-Liu
不太明白你的问题,例如红色EVB,右下角不就是嘛
437件の閲覧回数
Simon-Liu
Contributor V
Hi @Senlent
