hello:
I encouter a problem that:after called Power_Ip_SetMode(SOC_STANDBY),the current is 0.01A,when use gpio to wakeup,the board cann`t wakeup from standby.
i want ask that:
1. how to confirm the board enter to standby success?
2. all clock disable or other?if also have ips active when standby,the board cann`t enter standby entirely?
3. how to set the board entirely enter to standby? can give me a example to see?
thank you very much.
Hi @Jingjing
Please refer Table 25. STANDBY of the RM, this table in the section 4.5.8 mentions the state of pins of the device under standby mode.
Also take a look at this community post, where are attached some examples that can be helpful for you.
Wakeup MCU from standby
B.R
VaneB
thank you for reply.
"Please refer Table 25. STANDBY of the RM, this table in the section 4.5.8 mentions the state of pins of the device under standby mode."
which document mention the " the state of pins of the device under standby mode" ?
