s32k312 RTC not working
ソリューションへジャンプ
5,513件の閲覧回数
sunxujiang
I use Rtc and Wkpu components in my project. I want to wakeup mcu from standby by Rtc. But Rtc not working.I cannot upload my code due to company restrictions.
I reference S32K344_Standby_RTC_Wakeup_Example_090_34 code, but Rtc not working.
So,I need an example program which wake up from low power consumption through RTC based on S32K312。
Please help me,thanks.
5,481件の閲覧回数
VaneB
Hi @sunxujiang
I atached another project that in combination with S32K312_Wkup_RTC_GPIO project may be useful.
B.R.
VaneB
6 返答(返信)
5,498件の閲覧回数
sunxujiang
Hi, thank you very much for your reply. Can you provide an example that uses LLD's wkpu and RTC components? For some reason, we can't use mcal component and EB  in our project.
I think my code is correct, I am not sure where occurs wrong. Maybe misconfigurations of the relevant component.
5,482件の閲覧回数
VaneB
Hi @sunxujiang
B.R.
VaneB
4,644件の閲覧回数
GiangHM
Hi, Do you have example use MCAL and using S32DS (Not EB) to config ?
5,459件の閲覧回数
sunxujiang
Thanks a lot for your guidance. We will study it carefully.
5,502件の閲覧回数
VaneB
Hi @sunxujiang
I attached some examples for S32K344 that were created using RTD 0.9.0 which is not compatible with the current RTD 2.0.0 version, unfortunately.
But it shows how to configure the Power driver.
I also attached S32K312 RTD MCAL wakeup demo and S32K344 RTD LLD&MCAL wakeup demo.
I hope this will help you.
B.R.
VaneB
5,511件の閲覧回数
sunxujiang
Is there any problem in configuration?
