S32K312-The end address of DataFlash is incorrect
已解决
跳至解决方案
378 次查看
Simon-Liu
Contributor V
Hello
After using S32DS to generate the C40_Ip component, we found the following macros in the C40_Ip_Cfg.h file:
#define FLS_DATA_BLOCK_BASE_ADDR (0x10000000U)
#define FLS_DATA_BLOCK_END_ADDR (0x1000FFFFU)
According to the above macro, the size of DataFlash is 64K. However, the size of DataFlash of S32K312 is actually 128K. Is there any configuration item that I am not setting correctly?
BestRegards,
Simon
1 解答
361 次查看
Senlent
Hi@Simon-Liu
Could you please update your RTD, this could be a new update in latest RTD version.
For example,the picture from RTD 3.0.0
在原帖中查看解决方案
2 回复数
362 次查看
Senlent
Hi@Simon-Liu
341 次查看
Simon-Liu
Contributor V
Hi @Senlent
Thanks for your reply, I will try it using the new RTD generation code.
BestRegards
Simon
