Hello
After using S32DS to generate the C40_Ip component, we found the following macros in the C40_Ip_Cfg.h file:
#define FLS_DATA_BLOCK_BASE_ADDR (0x10000000U)
#define FLS_DATA_BLOCK_END_ADDR (0x1000FFFFU)
According to the above macro, the size of DataFlash is 64K. However, the size of DataFlash of S32K312 is actually 128K. Is there any configuration item that I am not setting correctly?
BestRegards,
Simon
Solved! Go to Solution.
Could you please update your RTD, this could be a new update in latest RTD version.
For example,the picture from RTD 3.0.0
