S32K3 How to setup RTC function
1,577件の閲覧回数
Foxconn
Hellow, I have created RTC function. RTC clock source uses external OSC (32.768k).
When opening the RTC driver UI window, the "RTC channel clock source" flag cannot be selected. It just shows "RTC_IP_CLOCK_SOURCE_".
How do i setup items and functions?
Used the SDK  "PlatformSDK_S32K3_2022_07_S32K324"
The clock source could be select source_0, source_1, source_2, source_3The clock source could be select source_0, source_1, source_2, source_3
1,541件の閲覧回数
Foxconn
Reset the CLK Setting in Run mode will fixed the issue. The "RTC Channel Clock Source" Item can setup to source_1
2 返答(返信)
1,542件の閲覧回数
Foxconn
1,560件の閲覧回数
Senlent
Hi@Foxconn
There may be some differences between this place and the old version,
When you select the specified clock for RTC in the clock configuration page, this option will not be changed.
for example:
