S32K188 runs with debugger, but not witout
3,610 次查看
albertgalofre
Hi there,
I have created a project with "S32DS Application project" button, over the S32k188 micro controller; it just a blinking led. Works fine debugging with the Mutilink Universal debugger; BUT I unplug this debugger and after a reset the led is fix to OFF. Seems that the microcontroller doesn't start to run. I have set the optimization to "None".
I have tried a "S32DS Project from example" button (hello_world_s32k118) and adding the blinking led code; and works fine with and without debugger!!!!!!
There is something different inside the project parameters, between the example and the application. I have compared them and matched some parameters, but with the same results.
IDE:   S32 Design Studio for ARM        Version: 2.2     Build id: 200116
Where I could be failing?
thanks a lot
标记 (3)
3,582 次查看
albertgalofre
understood, done and running!!!!!
Bravo for you, and bravo for the NXPCommunity.
Thanks a lot
8 回复数
3,583 次查看
albertgalofre
Thanks a lot
3,598 次查看
Robin_Shen
Hi albertgalofre,
Please add "START_FROM_FLASH" Symbols in "Standard S32DS Assembler".
Robin
598 次查看
binZhang01
I followed your instructions, but it didn't work. I am using the routine of S32K312
3,543 次查看
종찬박
Hi Robin.
I'm trying to solve same problem. but I can't see the tap that you let me see.
I think that's because I have another version S32DS.
I have S32 Design Studio for S32 Platform
 - Version: 3.3
 - Build id: 200610
I want to execute S32K188 without debugger.
What can I do?
3,539 次查看
Robin_Shen
Yes. There is a little different between S32DS 2.2 and 3.3.
You can open Standard S32DS Assembler -> Preprocessor and then add START_FROM_FLASH
337 次查看
Luxls
It does not work when I try this method to debug S32K312 EVB.
324 次查看
Robin_Shen
Please see the discussion here: If I don't give s32k312 delay, the CAN stop during operation
If the problem is still not solved, it is recommended to click ASK A QUESTION in the S32K community.
3,529 次查看
종찬박
I'm afraid that it doesn't work.
I did already what you said so, but my board doesn't work.
when I control my board with debugger, it works well.
but, After power reset, it doesn't work.
