S32K144 CAN can not transmit message by LSB(little-endian)?
1,039件の閲覧回数
中当陈
Hello, everybody!
I want S32K144 CAN to transmit message by LSB(little-endian).But I can't find which register to config. Could anyboby help me, Please?
 I tried to switch little-endian message to big-endian message, and then transmit it. But, I think its efficiency is too low.
2 返答(返信)
857件の閲覧回数
alexandrunan
CAN don't support this feature ! You need to do it by software. If you need as word for memory organisation you can use rev32 or rev16 asm instructions to revert it at level of byte.
857件の閲覧回数
中当陈
Thank you very much!
