I've generally had no problems with the various RTD examples I've tried to run. However, the Icu_BlinkLed_ASR_Ftm_S32K148 example does not seem to work as expected. The LED does not blink and the ISR is never called. Has anyone run into this problem?
(This is related to my earlier question about a button example, in the sense that one post suggested using the ICU, but if the ICU example doesn't work, that's very helpful.)
已解决! 转到解答。
