RAppID bootloader S32K144
4,128 次查看
sureshjayagonda
Hi NXP,
I am trying to use RAppID boot loader tool to download software to S32K144EVB through CAN interface.
Followed steps mentioned in below thread
https://community.nxp.com/thread/464653#comments
Also received a latest version of rbf file from NXp ( attached here ) and used that.
when i download "srec" file generated in example project "bootloader_S32K" using CAN i get following error.
Using Vector VN1611 LIN/CAN Interface for physical connection.
cid:ii_jhwgddm02_163bd2751e1d678f
But when i use serial communication selection in GUI i was able to download file successfully.
cid:ii_jhwgh5423_163bd2a01def86c9
Question is if tool is able to handle data through serial port using CAN cable connected to it, why am i getting the error when CAN is selected ? Hardware incompatible ? Software not seeing any data on CAN ??
Please help
Suresh J
6 回复数
2,047 次查看
bolei
hello Gopal, thank for your reply.. I find a rbf file which is attached.. while there is no source code. i am guessing that the app should be flashed since 0x2000 but the application is not launched properly...
i am afraid that the .ld file for my application is not fit the rbf...
here is the .ld setting for my application
 m_interrupts (RX) : ORIGIN = 0x00002000, LENGTH = 0x00000400
m_boot_data (RX) : ORIGIN = 0x00002400, LENGTH = 0x00000010
m_flash_config (RX) : ORIGIN = 0x00002410, LENGTH = 0x00000010
m_text (RX) : ORIGIN = 0x00002420, LENGTH = 0x0007A7E0
 do you have any idea/document about the s32k144_v11.rbf or what is the .ld setting should be if I want to use s32k144_v11.rbf?
many thanks,
bo
3,080 次查看
jiri_kral
Hi Suresh,
I'm afraid that RappID suports only couple of Vector CAN interfaces (CANCaseXL, CANCardXL/XLE), not generic Serial (USB Serial to CAN) cables.
You can try to use Serial port which your cable uses (use Serial instead CAN - you probably already give it chance) , but in my opinion this will not work.
Jiri
2,763 次查看
rathi_tg
Hello @jiri_kral @sureshjayagonda
I am using Rappib Bootloader and Vector Tool (VN1630).
I am using the rbf file provided by @sureshjayagonda (Copy and paste to the driver).Is that a right way to flash rbf?
I get
Could you Please let me know what is the issue.
Gopal Rathi
2,066 次查看
bolei
hello Gopal, i am in the same boat...
did you fix the problem? is there a link about the 'rappid bootloader' file which need to be flashed first?
--bo
2,057 次查看
rathi_tg
hi @bolei
Yes, I have resolved the issue. If you are using NXP ToolBox you can once check the ToolBox Folder. It contains a folder name Rappid Bootloader which contain various rbf files.
Gopal
2,047 次查看
bolei
many thanks,
bo
