Question regarding OSIF driver
2,295件の閲覧回数
kyf
Contributor V
Hello NXP team.
I would like to know what OSIF means and some stuff about their configurations.
1. What does "Dev Error Detect" enable ? Does it enable asserions that check/detects the errors regarding Osif driver ?
2. What does "Use system timer" option ? In which system timer does this configuration refer to ? Is it the SysTick of CM7 ?
3. What does "Custon Timer" option enable ??
4. What is instance ID ? Does this refer to MCU ID or it is something else ?
Kind regards,
kyf
2,286件の閲覧回数
JRoberto
Hello @kyf
Osif is the name given to the OS Interface driver.
Kindly let me suggest to review the osif driver's documentation by doing right click on the driver and selecting the documentation item. as shown in the image.
In there you can find all the parameters and their usage.
Best Regards!
2 返答(返信)
2,269件の閲覧回数
kyf
Contributor V
Thank you for your answer @JRoberto
2,287件の閲覧回数
JRoberto
Hello @kyf
Best Regards!
