Hi.
Interrupt api is not called in case of SMR Verification is Periodic in S32K3.
Could you please let me know why Interrupt api is not called?
Solved! Go to Solution.
Hello @HyunungPark1,
Sorry for my late response.
Did you check the below bits in your program?
Could you send me the code implemented in the CDD_InitFTDConfiguration() function and Fls configuration?
And what is the HSE Firmware you are using?
Dan
Hi.
below is the information for RTD and HSE Firmware which I used
Hi.
I saw that you have not called "Hse_Ip_Init(MU0_INSTANCE_U8, &HseIp_MuState);" in your code to init MU_0.
So, you need to call "Hse_Ip_GetHseStatus(MU0_INSTANCE_U8);" and "Hse_Ip_Init(MU0_INSTANCE_U8, &HseIp_MuState);" after "IntCtrl_Ip_EnableIrq(HSE_MU0_ORED_IRQn);"
Dan
This issue is not resoived.
Hyunung Park
I have a question: when you perform step 6 (Reset Device) then after that: Is your program run step 1 to 5 again?
Dan
Hello Dan
My program doesn't run step 1 to 5 again after step 6 (Reset Device)
Best Regards.
Hyunung Park
If your program doesn't run step 1 to 5 again after step 6 (Reset Device) then it mean the value of registers was reset and indicated that HSE_MU0_ORED interrupt was not enable when you perform test.
Dan
Hello Dan.
I think that HSE_MU0_ORED interrupt is enable because the below code is performed after device reset
/* Install ORed GP interrupt for MU-0 */
IntCtrl_Ip_InstallHandler(HSE_MU0_ORED_IRQn, &Mu_Ip_Mu0_OredGP_Isr, NULL_PTR);
/* Enable ORed RX interrupt for MU-0 */
Best Regards.
Hyunung Park
Hi.
This issue is resloved.
Hyunung Park
