Hi.
Interrupt api is not called in case of SMR Verification is Periodic in S32K3.
Could you please let me know why Interrupt api is not called?
已解决! 转到解答。
Hello @HyunungPark1,
Sorry for my late response.
Did you check the below bits in your program?
Hi.
below is the information for RTD and HSE Firmware which I used
Hi.
I saw that you have not called "Hse_Ip_Init(MU0_INSTANCE_U8, &HseIp_MuState);" in your code to init MU_0.
So, you need to call "Hse_Ip_GetHseStatus(MU0_INSTANCE_U8);" and "Hse_Ip_Init(MU0_INSTANCE_U8, &HseIp_MuState);" after "IntCtrl_Ip_EnableIrq(HSE_MU0_ORED_IRQn);"
Dan
If your program doesn't run step 1 to 5 again after step 6 (Reset Device) then it mean the value of registers was reset and indicated that HSE_MU0_ORED interrupt was not enable when you perform test.
Dan
Hello Dan.
I think that HSE_MU0_ORED interrupt is enable because the below code is performed after device reset
/* Install ORed GP interrupt for MU-0 */
IntCtrl_Ip_InstallHandler(HSE_MU0_ORED_IRQn, &Mu_Ip_Mu0_OredGP_Isr, NULL_PTR);
/* Enable ORed RX interrupt for MU-0 */
Best Regards.
Hyunung Park
