Hi. I want to run SCST ins 32k144 EVB. there is 2 question for me:
1. is there any validation report from NXP or other company or institute about SCST library?
2. is SCST support IAR compiler?
3. when I see user manual of SCST, latest version was 1.04 and in 2018, is there any newer update ? (if yes, how we can download it)
Thanks.
Thanks.
a. See your account on nxp.com: https://www.nxp.com/ruhp/myAccount.html?
b. Select Software Licensing and Support
c. Search for the SCST. There should be quality pack available for download which contains test reports.
If you can find SCST in the list, click on (I'm not sure if you downloaded this version or if you use package from Design Studio):
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=SW32K14-M4SCSTE
2. Yes, IAR is supported.
3. Yes, that's the latest version.
Lukas
as mentioned in the safety manual, it should be executed periodically once within Fault Tolerant Time Interval.
The safety manual can be downloaded here:
https://community.nxp.com/t5/SafeAssure-NDA-group/Safety-Manual-S32K1xx-Series/ta-p/1103524
Notice that you need to get access rights as described here:
Lukas
Hi Lukaszadrapa:
First of all, thank you for your prompt reply, but your reply did not help me solve my question, or it was caused by my lack of a clear description of my question. Let me give you an example. If I want to call the DSP instruction set, I think the routine is called once before the program while(1). Is it enough to call it once? What if the DSP instruction set is calculated incorrectly during the program? how to do?
The requirement given by safety manual is to execute the test once within one FTTI. We are talking about situation when safety application is being executed. During bootloader execution (if no safety application is executed), it's not required.
