How to correctly configure and use the "Mem Start Flash Access Notification" parameter for S32K312?
1,316 次查看
Chris-Sun
I am currently working on a project involving the S32K312 chip and using S32DS for configuring the Flash.
Errors occurred after configuring the "Mem Start Flash Access Notification" parameter for S32K312.
Could anyone please provide some guidance or advice on how to configure and use the "Mem Start Flash Access Notification" parameter correctly?
The version information:
S32DS: 3.5
RTD: S32K3_RTD_3_0_0_D2303_ASR_REL_4_7_REV_0000_20230331
Thank you in advance for your assistance.
11 回复数
858 次查看
RogerFranca
Hi!
I have the same problem, but I already have a large part of my application developed and changing RTDs would not be ideal.
Would there be any explanation to solve the C40 problem with the RTD setup in the first image published in this topic?
838 次查看
Chris-Sun
Unfortunately, I was only able to solve this problem by upgrading the version of RTD and couldn't find any other solution.
1,302 次查看
Senlent
Hi@Chris-Sun
Could you please have a try to update the code.
If the error still exists, I hope you can provide your project
1,294 次查看
Chris-Sun
Hi @Senlent
Thank you for your response to my post.
I tried to update the code, but there are still errors.
Attached is the project I used.
Chris
1,275 次查看
Senlent
Hi@Chris-Sun
I imported the project you provided, and the interface displayed is a little different.
however I didn't find any problems.
1,273 次查看
Chris-Sun
Hi @Senlent
According to the screenshot you provided, the configuration pages for C40 are different, and the "Mem Start Flash Access Notification" configuration option is missing. (The error I encountered during configuration might be caused by this option.)
Is it possible that we are using different versions?
S32DS: 3.5
Chris
1,271 次查看
Senlent
Hi@Chris-Sun
Can you try installing this version
There are many versions of RTD 3.0.0, and I can't adapt to all of them on my computer at the same time.
1,187 次查看
Chris-Sun
Hi @Senlent
After using the RTD version you mentioned earlier, I no longer receive any errors, and the graphical interface of the configuration item has also changed.
Does this imply that only specific version RTD support the "Mem Start Flash Access Notification" configuration?
1,173 次查看
Senlent
Hi@Chris-Sun
I don’t think RTD has such obvious problems.
As I replied to you before, since the versions you and I use are different, I cannot help you troubleshoot the problem (unless I install an older version of RTD). I think this should still be a problem with certain configuration option settings.
1,183 次查看
Senlent
Hi@Chris-Sun
 I think "Mem Start Flash Access Notification" is just same with the below highlight part.
1,177 次查看
Chris-Sun
Yes.
What I mean is, previously when I used the following RTD version and configured "Mem Start Flash Access Notification", it resulted in many errors (as shown in the image I added earlier).
Then I installed this version of RTD and configured "Mem Start Flash Access Notification", and there were no errors. Additionally, the graphical interface of the configuration has changed.
From this, can we conclude that the configuration of "Mem Start Flash Access Notification" has issues in a certain version of RTD and works properly in other versions?
Chris
