How to calculate the watchdog timeout
4,062件の閲覧回数
建宽高
  • As the title suggests ,How to calculate the watchdog timeout?  or What api are available to provide timeout?
タグ(1)
6 返答(返信)
3,623件の閲覧回数
danielmartynek
I have difficulties to understand, can you please elaborate?
3,623件の閲覧回数
建宽高
sorry , I didn't express my meaning
In the S32k144 environment, how does the watchdog timeout calculate,
Can provide the relevant calculation formula about watchdog time out
3,623件の閲覧回数
danielmartynek
The timeout depends on the
  • WDOG clock source (WDOG_CS_CLK),
  • on the prescaler if enabled (WDOG_CS_PRES),
  • and on the value in Timeout Value Register (WDOG_TOVAL).
You can use the SDK WDOG driver:
Please refer to wdog_interrupt_s32k144 SDK example in S32 Design Studio:
3,623件の閲覧回数
建宽高
yes, i know about your reply
i know  watch timeout about  clock,prescaler and timeout value
can you provide calculation formula about wdg timeout?
such as
timeout = (1/(clk/(prescaler+1)) ) * timeout_value      (ms)  ?
is ths right?
thank you for your reply!   ☺
3,623件の閲覧回数
danielmartynek
timeout (s) = (1 / clk) * TOVAL
or
timeout (s) = 256 * (1 / clk) * TOVAL
3,623件の閲覧回数
bjrajendra
Senior Contributor I
Hi Daniel,
I would like to know for a TOVAL of 2 with PRESCALAR Enable what exactly will be the watchdog timeout period.
Also can you kindly elaborate when the two formulae will be used you mentioned above?
Thanks in advance,
Raju
