How to calculate the watchdog timeout
3,522 次查看
建宽高
  • As the title suggests ,How to calculate the watchdog timeout?  or What api are available to provide timeout?
标记 (1)
6 回复数
3,083 次查看
danielmartynek
I have difficulties to understand, can you please elaborate?
3,083 次查看
建宽高
sorry , I didn't express my meaning
In the S32k144 environment, how does the watchdog timeout calculate,
Can provide the relevant calculation formula about watchdog time out
3,083 次查看
danielmartynek
The timeout depends on the
  • WDOG clock source (WDOG_CS_CLK),
  • on the prescaler if enabled (WDOG_CS_PRES),
  • and on the value in Timeout Value Register (WDOG_TOVAL).
You can use the SDK WDOG driver:
Please refer to wdog_interrupt_s32k144 SDK example in S32 Design Studio:
3,083 次查看
建宽高
yes, i know about your reply
i know  watch timeout about  clock,prescaler and timeout value
can you provide calculation formula about wdg timeout?
such as
timeout = (1/(clk/(prescaler+1)) ) * timeout_value      (ms)  ?
is ths right?
thank you for your reply!   ☺
3,083 次查看
danielmartynek
timeout (s) = (1 / clk) * TOVAL
or
timeout (s) = 256 * (1 / clk) * TOVAL
3,083 次查看
bjrajendra
Senior Contributor I
Hi Daniel,
I would like to know for a TOVAL of 2 with PRESCALAR Enable what exactly will be the watchdog timeout period.
Also can you kindly elaborate when the two formulae will be used you mentioned above?
Thanks in advance,
Raju
