How do I configure SPLL CLK?
1,049件の閲覧回数
jinsheng20
1,039件の閲覧回数
Robin_Shen
Hi jinsheng20,
The Phase-locked loop (PLL) is not available for the S32K11x product series. That is why you cannot configure it.
Robin
2 返答(返信)
1,040件の閲覧回数
Robin_Shen
Hi jinsheng20,
Robin
1,037件の閲覧回数
1090097669
Hi Robin,
according to Datasheert,the  and the current consumption it is 21mA,and following Code which the current consumption it is 4mA,it should be less than 1mA.
how to further reduce the current consumption by the controller?
 And also how to disable the clock monitors?
And if possible also let me know how to come to normal RUN mode through CAN
Please point out my configuration errors or missing areas
void power_cp_wakeup_set(void)/*E5*/
PINS_DRV_SetPinIntSel(GPIO_CP_WAKE_PORT,GPIO_CP_WAKE_PIN,PORT_INT_RISING_EDGE);
void init_NVIC(void)
power_cp_wakeup_set();
INT_SYS_ClearPending(PORTE_IRQn);
INT_SYS_SetPriority(PORTE_IRQn, 0);
// PORTE_interrupt
S32_NVIC-> ICPR [1] = (1 <<(63%32));
S32_NVIC-> ISER [1] = (1 <<(63%32));
S32_NVIC-> IP [63] = 0x10;
PORTE-> DFER |= (1 << 5);
void Power_RUN_to_STOP (void)
#if 0
/* Set the SLEEPDEEP bit to enable deep sleep mode (STOP) */
S32_SCB->SCR |= S32_SCB_SCR_SLEEPDEEP_MASK;
/*select stop mode*/
SMC->PMCTRL = SMC_PMCTRL_STOPM(0b00);
SMC->STOPCTRL = SMC_STOPCTRL_STOPO(0b01);
if(SMC->PMSTAT == 0x01)
asm("WFI");
#else
/* Disable the JTAG port pins */
/* Disable Adc Pins */
PMC->REGSC |= PMC_REGSC_BIASEN(1); // [1] CLKBIASDIS = 1 In VLPS mode, the bias current for SIRC, FIRC, PLL is disabled
/* Disable the Fosc and Sosc from chip*/
SCG->FIRCCSR = SCG_FIRCCSR_FIRCEN(0);
while(SCG->FIRCCSR & (1 << 24));
SCG->SOSCCSR = SCG_SOSCCSR_SOSCEN(0);
S32_SCB->SCR |= S32_SCB_SCR_SLEEPDEEP_MASK|0x2; /* allow deep sleep mode0 */
SMC->PMPROT = SMC_PMPROT_AVLP(1); /* allow very low power mode*/
SMC->PMCTRL = SMC_PMCTRL_STOPM(2);
asm("WFI");
#endif
void power_set_mode(POWER_SYS_TYPE mod)
if(mod == POWER_SYS_SLEEP)
init_NVIC();
//power_can_wakeup_set();
Power_RUN_to_STOP();
Katrinal
