HSE code errors
HSE code errors
142 次查看
vikmonti7804
   I am creating a seperate project for the HSE where i am adding the services, frameworks and interface folder from the example code, i am getting some erroe and i am keep including the respective header files to the source code but the errors are still there and i am not able to remove them. these error seems to be related to some settings. kindly look and help  to remove them.
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_get_capabilities.c:82: undefined reference to `gsrvResponse'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_get_version.c:123: undefined reference to `gHseFwVersion'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `write_attr'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `WriteMu1Config'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/non-otp/hse_mu_config.c:129: undefined reference to `ReadMu1Config'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_advance_LC.c:157: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_advance_LC.c:157: undefined reference to `write_attr'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_boot_auth.c:153: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_boot_auth.c:153: undefined reference to `write_attr'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_auth_mode.c:136: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_auth_mode.c:136: undefined reference to `write_attr'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_key.c:299: undefined reference to `write_attr'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_debug_key.c:299: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/fw_attribute/otp/hse_extend_cust_security_policy.o: in function `ExtendCustomerSecurityPolicyService':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `write_attr'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `GetStartAsUserBit'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_attribute/otp/hse_extend_cust_security_policy.c:148: undefined reference to `GetEnableAdkmBit'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/fw_update/standard/hse_fw_update.o: in function `firmwareUpdateService':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `fwudpate_only'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `ActivatePassiveBlock'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/fw_update/standard/hse_fw_update.c:402: undefined reference to `gHseFwVersion'
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:27: undefined reference to `gProgramAttributes'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:27: undefined reference to `gsrvResponse'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/hse_demo_app_config.o: in function `CopyFlashToSRAMHseHost':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:75: undefined reference to `HSE_HOST_FLASH_SRC_START_ADDR'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:75: undefined reference to `HSE_HOST_FLASH_SRC_END_ADDR'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:75: undefined reference to `HSE_HOST_RAM_DST_START_ADDR'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/hse_demo_app_config.o: in function `attributeProgrammingService':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_demo_app_config.c:172: undefined reference to `gEnableIVTAuthBit'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: ./services/src/hse_host_flash.o: in function `HostFlash_Init':
C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_host_flash.c:156: undefined reference to `FLASH_DRIVER_FLASH_SRC_START_ADDRESS'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_host_flash.c:156: undefined reference to `FLASH_DRIVER_FLASH_SRC_END_ADDRESS'
c:/nxp/s32ds.3.4/s32ds/build_tools/gcc_v10.2/gcc-10.2-arm32-eabi/bin/../lib/gcc/arm-none-eabi/10.2.0/../../../../arm-none-eabi/bin/real-ld.exe: C:\Work\Projects\Crypto_TS_T40D34M20I3R0\examples\S32DS\Hse_Ip_AesEncAsyncIrq_S32K312\Debug_FLASH/../services/src/hse_host_flash.c:156: undefined reference to `FLASH_DRIVER_RAM_DST_START_ADDRESS'
make: *** [makefile:55: Hse_Ip_AesEncAsyncIrq_S32K312.elf] Error 1
0 回复数
