FreeRTOS IIC_Deinit
FreeRTOS IIC_Deinit
943件の閲覧回数
fancycang
Hi everyone
When I enable task scheduling and uninitialize the IIC module, an error occurs,becouse of OSIF_SemaDestroy(). why?
5 返答(返信)
942件の閲覧回数
fancycang
I2C_MasterDeinit() and use flexio for iic
902件の閲覧回数
PetrS
was I2C_MasterInit() called before, which should create osifSema?
BR, Petr
897件の閲覧回数
fancycang
Hi petr
I'm glad to receive your reply. I created a task and started task scheduling.
This is my code
I2C_MasterInit(&flexio_instance, &i2c_pal_flexio_MasterConfig0);
/* Initialize Interrupt priority for FlexIO I2C driver as bus master */
INT_SYS_SetPriority( FLEXIO_IRQn, configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY );
I2C_MasterDeinit(&flexio_instance);
After this line of code  "(void)OSIF_SemaDestroy(&(master->idleSemaphore));"
 and the code jump to "portFORCE_INLINE static void vPortRaiseBASEPRI( void )"
I do not know how to receive this problem........
847件の閲覧回数
PetrS
maybe this happens due to the lack of heap and stack of the task, so to avoid this try to increment the task's stack and the Total heap size.
BR, Petr
842件の閲覧回数
fancycang
Hi petr
i think my code heap and stack enough size
i finish this promble ,use function change i2c address
