Can the binary file downloaded to the evaluation board flash be saved to a computer?
900件の閲覧回数
testyoung
I am using the NTBMS evaluation board.
The downloader uses PE Multilink Universal.
I would like to check if the software provided by NXP and the file downloaded to the evaluation board flash are the same.
Can I load the .elf file written on the flash to my computer? Or is it possible to verify with the compiled .elf file?
859件の閲覧回数
Robin_Shen
Hi testyoung,
You may need to use PROGACMP ARM Flash Programming Software for Multilink and Multink FX debug probes.
About how to use PROGACMP with Multilink, you can read the manual or ask question in forums of PEMicro.
Robin
2 返答(返信)
860件の閲覧回数
Robin_Shen
Hi testyoung,
Robin
847件の閲覧回数
testyoung
Thank you!
