Bootloader for S32K344 evk
1,290 次查看
sathishkumar-rk
Hi Team,
I'm using S32K344 evk board for development project, from where can i get the bootloader file for board?
Sathishkumar K
5 回复数
326 次查看
JonAnder_Amante
I am using the project "S32K344_Can_bootloader_RTD200" in the microprocessor S32K344. I want to download an application with the program of bootloader. I have achieved the jump from program to application but I have different questions.
1. I want to use #define EN_DELAY_TIME but when I uncomment the command in the folder "public_inc", the program has different errors. My target to use "Backdoor", that is to say, I want to check if the program has to enter to bootloader or not. I don´t know the process and the different functions that I have to use to achieve the target. I want to use the function "Boot_CheckReqBootloaderMode(void)" but when I debug the program, it never enters to the "if". Could you explain me the process and the steps to achieve the target. I add different functions that I think are important.
2. I don´t know if I have to modificate the parameters of "static tJumpAppDelayTimeInfo gs_stJumpAPPDelayTimeInfo = {FALSE, 0u};". I have to change this structure ? You can see all structure in one of the next pictures.
I need the reply as soon as possible since I have to send a project very soon.
Thank you for all,
Jon Ander Amante Jorge
1,271 次查看
VaneB
Hi @sathishkumar-rk
Please take a look at this community post: Unified bootloader Demo.
B.R.
VaneB
1,258 次查看
sathishkumar-rk
Thanks @VaneB,
I'm curious to know, how to prepare the secure bootloader for S32K3xx device.
I'm wondering there might be some application note available for that, can you please point to out !
Sathishkumar K
标记 (1)
1,252 次查看
VaneB
Hi @sathishkumar-rk
What we have are:
The Unified bootloader previously mentioned (no HSE is used), and there is support in HSE firmware. You can download HSE FW and HSE demo app, HSE OTADEMO for A/B Swap from S32K3 Standard Software and S32K3 Reference Software packages.
1,127 次查看
sathishkumar-rk
Hi @VaneB,
I have downloaded the HSE FW and Demo App.
From the documents i understood that HSE FW will encrypted using NXP FDK and signed using NXP FSK.
1. So, how HSE FW will authenticated by BootROM on POR/reset?
2. The FDK & FSK information's where it will get stored?
Sathishkumar K
