ADC with PDB Triggering Question S32k144
1,961件の閲覧回数
marwanibrahim
I am using S32k144 and i want to configure ADC to be triggered with PDB timer which got triggered with TriggerMux.
I want to use ADC without polling for the COCO flag, and without interrupts also, just a timer triggers pdb timer which triggers.
I have some questions:
1- To be able to do that, is it mandatory to configure ADC to work with DMA?
2- If not, am i getting the idea right? if yes, how should the configuration process go?
3- Is there an example for that?
That's for now, appreciate your kind support.
Thank you.
タグ(4)
1,902件の閲覧回数
PetrS
you cannot trigger ADC by PDB without reading ADC results. Words from the RM...
"When a pre-trigger from a PDB channel n is asserted, the associated lock of the pre-trigger becomes active. The associated lock is released by the rising edge of the corresponding ADCnSC1[COCO]; the ADCnSC1[COCO] should be cleared after the conversion result is read, so that the next rising edge of ADCnSC1[COCO] can be generated to clear the lock later."
1) to do not operate with interrupt or polling flag the DMA usage is advisable
2-3) you can refer to Example S32K144 PDB ADC trigger DMA ISR S32DS or SDK based examplehttps://community.nxp.com/docs/DOC-343295 .
BR, Petr
