QNX Hypervisor Error on s32g
363 次查看
lewis123
I am running QNX hypervisor on S32G-VNP-RDB2.
The hypervisor host can boot normally(I also built Arm Trusted firmware and uboot). But the guest failed.
Then I run "qvm-check", I get the following error:
Virtualization is available, but not enabled by the IPL.
Process 77845 (qvm-check) exited status=2.
What should I do to make the guest run properly?
328 次查看
chenyin_h
Hello, @lewis123
QNX hyperviser is the 3rd party software that is not developed by NXP, thus is not directly supported, we can recommend contacting the QNX support team, for them to provide you with better information that the one we can provide at this moment.
We do apologize for the inconvenience.
Chenyin
329 次查看
chenyin_h
Hello, @lewis123
Chenyin
253 次查看
lewis123
Thank you.
