Hi all,
I'm getting the following errors when trying to use the STM2 driver as shown in Chapter 14: SoC Level Time Source in the Linux BSP 30.0 user manual.
Init driver
root@s32g274ardb2:~# echo 1 > /sys/devices/platform/40124000.stm/init
-sh: /sys/devices/platform/40124000.stm/init: Permission denied
Reading Timer Value
root@s32g274ardb2:~# cat /sys/devices/platform/40124000.stm/value
cat: /sys/devices/platform/40124000.stm/value: No such file or directory
The kernel has been patched successfully and bitbake virtual/kernel generated Image and dtb without any errors. This is confirmed by looking at the runtime kernel config:
root@s32g274ardb2:~# zcat /proc/config.gz | grep GLOBAL
CONFIG_FSL_GLOBAL_TIME_STM=m
Kernel Config
In fsl-s32-gen1.dtsi (tmp/work/s32g274ardb2-fsl-linux/linux-s32/5.10.41-r0/git/arch/arm64/boot/dts/freescale/fsl-s32-gen1.dtsi), I changed the status of the STM2 device node to "okay":
stm2: stm@40124000{
compatible = "fsl,s32gen1-stm-global";
reg = <0x0 0x40124000 0x0 0x3000>;
clocks = <&clks S32GEN1_SCMI_CLK_STM_MODULE>;
clock-names = "stm";
status = "okay";
In s32gen1_defconfig (tmp/work/s32g274ardb2-fsl-linux/linux-s32/5.10.41-r0/git/arch/arm64/configs/s32gen1_defconfig) CONFIG_FSL_GLOBAL_TIME_STM=m was appended to the end like so:
# CONFIG_RUNTIME_TESTING_MENU is not set
I then created a patch and copied it to sources/meta-alb/recipes-kernel/linux/linux-s32, which get append to the end of linux-s32_5.10.bb file like so:
SRC_URI += " file://0001-Enable-Global-Time-Source-and-STM2-device-tree.patch"
After this, kernel is cleaned and build with the following commands:
bitbake -c cleansstate virtual/kernel
The output Image and DTS file is transferred to SD card FAT partition and everything booted up successfully.
已解决! 转到解答。
Hi Kawin
Sorry, I misunderstood your question before.
There is nothing wrong with your operation. Did you forget to load the '*stm.ko' module ?
In addition, you can run the 'git status' command in the linux kernel directory to check whether the patch has been applied.
Hi Kawin
Hi Kawin
That is not going to work. You should enable the global stm timer from menuconfig menu with 'bitbake -c menuconfig virtual/kernel'.
Device Drivers ->Clock Source drivers->
save and re-compile the kernel.
Below is the test procedure
step1. Boot to reach the Linux console.
step2. Insert the 'fsl_global_time.ko' kernel module with "insmod /lib/modules/5.10.41-rt42+g98b692708f63/kernel/drivers/clocksource/fsl_global_time.ko"
step3.
This should be a document description error.
Hi Andrei,
Could you give me some explanation on why patching defconfig directly wouldn't work? Is there a mistake in the documentation? In any case, should general procedure of patch -> clean -> build work? Since a patch should get applied before the compilation.
Thank you,
Kawin
