Hi ,
I installed the software for SWS32R294_Radar_SDK_1.3.0_D2105.exe in path C:\NXP
But when I open the example in the S32 Design Studio for Power Architecture Version 2.1,create S32DS PROJECT FROM EXAMPLE ,import RSDK_Multi_RFE_example_S32R294,show File not found: /RSDK_Multi_RFE_example_S32R294/src/core0/main_c0.c.
The problem is that there are files in the RSDK path, but not in the workspace after import, so which step is wrong
Latest info is that next release is in mid August and they will take care of the issue there.
Peter
From your description it looks like all you need to do is to set correctly path to the source files in your project.
Could you post some screenshots of the errors?
Peter
I was talking with RSDK team, they will debug the issue in following days.
I will update you ASAP.
best regards,
Peter
