S32R294_RSDK_1_3_0
S32R294_RSDK_1_3_0
2,246件の閲覧回数
tyson1
Hi ,
    I installed the software for SWS32R294_Radar_SDK_1.3.0_D2105.exe in path C:\NXP
  But when I open the example in the S32 Design Studio for Power Architecture Version 2.1,create S32DS PROJECT FROM EXAMPLE ,import RSDK_Multi_RFE_example_S32R294,show File not found: /RSDK_Multi_RFE_example_S32R294/src/core0/main_c0.c.
The problem is that there are files in the RSDK path, but not in the workspace after import, so which step is wrong
4 返答(返信)
2,065件の閲覧回数
petervlna
Latest info is that next release is in mid August and they will take care of the issue there.
Peter
2,238件の閲覧回数
petervlna
From your description it looks like all you need to do is to set correctly path to the source files in your project.
Could you post some screenshots of the errors?
Peter
2,236件の閲覧回数
tyson1
S32R294_RSDK__1_3_0   path in C:\NXP
2,231件の閲覧回数
petervlna
I was talking with RSDK team, they will debug the issue in following days.
I will update you ASAP.
best regards,
Peter
