S32K146 eDma transfer
2,044件の閲覧回数
albertoferrero
Hi all, I need to implement a dma transfer from memory to a register, triggered by a timer. The platform is a S32K146 with S32DS 3.4 and SDK 4.0.2. I tried to modify the "edma_transfer_s32k146" example in order to setup the FlexTimer FTM1 - channel 1 as a PWM generator (checking the "External Trigger" box) and setting the EDMA field "Channel Request" on EDMA_REQ_FTM1_CNANNEL_1 value.
In the source code I simply added a call to start the DMA channel
EDMA_DRV_StartChannel(dmaControllerChn0_Config.virtChnConfig);
Could someone give me any advice to make this working? Is there, on the Net, any example on using DMA driven by a timer? Should I use the TRGMUX module?
Thank you all in advance.
Alberto
2,035件の閲覧回数
danielmartynek
