I'd like to attach the jLink debugger to my running device (an S32K148) on our board without resetting the device. I've checked the "Connect to running target" checkbox on the Debug Configuration window Debugger tab, and tried to uncheck various checkboxes on the Startup tab but the device is always reset when I press Debug. On the EVB board with the pemicro debugger there is an "Attach to running target" on the Debugger tab which works just fine, but I need to use the jLink on our board. Any idea how to set this up?
Freddy
Hi Freddy,
this is known issue - but I'm afraid, that not solved yet - https://community.nxp.com/message/1155473
Jiri
