Dear Sir,
I am using RAppID bootloader for S32K144 & MPC5744p for CAN-UART Flash.
However, I cannot find any release note of S32K144 settings parameters in " S32K144.rbf " file.
Ex;
Which CAN_PORT are they using ? Which Buad_Rate is conconfigured ?
What memory address map are allocated ?
Can you help point me the direction to the file_link ?
Narudol T.
解決済! 解決策の投稿を見る。
I can share the following information:
Device |
Communication supported |
Device tested |
RBF file |
Boot-loader areas |
CAN(500Kb/s) |
UART(115200b/s) |
S32K116 |
CAN0 (PTE4-PTE5) |
UART0 (PTB0-PTB1) |
PS32K116MLF- Q048 |
S32K116.rbf |
0x00000000 - 0x00001FFF |
S32K118 |
CAN0 (PTE4-PTE5) |
UART1 (PTC8-PTC9) |
PS32K118LAMLH |
S32K118.rbf |
S32K142 |
CAN0 (PTE4-PTE5) |
UART0 (PTC2-PTC3) |
PS32K142LAMLH |
S32K142.rbf |
S32K144 |
CAN0 (PTE4-PTE5) |
UART0 (PTC2-PTC3) |
PS32K144HFVLL-0N77P-Q100 |
S32K144.rbf |
S32K146 |
CAN0 (PTE4-PTE5) |
UART1 (PTC6-PTC7) |
PS32K146UAVLQ-0N73V |
S32K146.rbf |
S32K148 |
CAN0 (PTE4-PTE5) |
UART1 (PTC6-PTC7) |
PS32K148UAVLU-0N20V |
S32K148.rbf |
and
Device |
Device tested |
RBF file |
Boot-loader areas |
CAN (500Kb/s) |
UART (115200b/s) |
rchw |
m_text |
MPC5744P |
CAN0 (PB0-PB1) |
UART2 (PF14-PF15) |
MPC5744P-FML09 1N15P MPC5744P-FMLQ8 0N65H PPG5744P-FMMM8 0N65H |
MPC5744P.rbf |
0x00F98000 - 0x00F98004 |
0x00F98008 - 0x00F9FFFF |
Hope that helps!
Mike
Device |
Device tested |
RBF file |
Boot-loader areas |
CAN(500Kb/s) |
UART(115200b/s) |
S32K116 |
CAN0 (PTE4-PTE5) |
UART0 (PTB0-PTB1) |
PS32K116MLF- Q048 |
S32K116.rbf |
S32K118 |
CAN0 (PTE4-PTE5) |
UART1 (PTC8-PTC9) |
PS32K118LAMLH |
S32K118.rbf |
S32K142 |
CAN0 (PTE4-PTE5) |
UART0 (PTC2-PTC3) |
PS32K142LAMLH |
S32K142.rbf |
S32K144 |
CAN0 (PTE4-PTE5) |
UART0 (PTC2-PTC3) |
S32K144.rbf |
S32K146 |
CAN0 (PTE4-PTE5) |
UART1 (PTC6-PTC7) |
S32K146.rbf |
S32K148 |
CAN0 (PTE4-PTE5) |
UART1 (PTC6-PTC7) |
S32K148.rbf |
and
Device |
Device tested |
RBF file |
Boot-loader areas |
CAN (500Kb/s) |
UART (115200b/s) |
rchw |
m_text |
MPC5744P |
CAN0 (PB0-PB1) |
UART2 (PF14-PF15) |
MPC5744P.rbf |
Hope that helps!
Mike
Hi @mikedoidge
Yes this helped a lot, thank you very much.
May I also ask more detail about device package ?
As I saw table include tested device as well.
For example S32K144 .... mostly are 100pin package.
But This bootloader also work with 48-64pin package as well, right ?
(As long as the PORT channel&number are correct)
Narudol T.
Yes, you are correct. It works for the other pin packages, but wasn't specifically tested on them. So if the package contains the same ports then it leaves just the board design as the remaining factor.
Mike
HI @mikedoidge
I see, may I ask another question as I saw you listed other S32K1xx device as well.
However, the bootloader utility have only S32K144 device.
How would I get those file/bootloader as well like S32K118 ?
Many Thanks,
Narudol T.
Hello @Narudol-T,
There was some effort made some years ago to create a new version of the RAppID Bootloader, but it was never released. This version contained separate files for each member of a device family. This is why you see the separate filenames listed in the table I shared. The table is from a document that was created as part of this never released version, but it is useful in supporting questions from users, like yourself. The file for S32K144 should work just as well for S32K118. The differences between the devices should not impact the flash algorithm. The core and relevant peripherals are the same. The difference in UART ports (0 vs. 1) is due to the UART to USB connection on evaluation board. If you are using the S32K118EVB, then you would need to use UART1 instead of UART0 for the RAppID Bootloader. If you have a custom board, it would depend upon which UART was used to connect to the serial interface.
Hope that answers your question.
Mike
