I have some problem in my project. I use S32K144-Q100.
This project use LPTMR module to make up scheduler. (scheduler means periodically operating functions)
When click debug button, 0x410 popup create.
There is some message that No source available for "0x410".
It doesn't problem to run program. but i care about this.
I attached my project, please check some of human error.
Regard,
Minkyu.
已解决! 转到解答。
missing source for address 0x410 means that debugger can't find source code for that address. You can use disassembly feature for that particular address. For some reason - startup_S32K144.S file is not visible debugger on your machine.
In your project is on that address 0x410 Reset Handler and program already passed through. Break point on main() function is set by default in Debug session config:
You can try HW reset. After that is program stopped on the very first instruction:
It is also possible that you have disabled debug info for assembler:
Hope it helps.
Jiri
on 0x410 address is reset handler written in Assembly language. By default - first breakpoint is in main() function and as you can see on your screenshot - the program is stopped there - address 0x798.
I tried your program - and there is no issue on my side. When you close the 0x410 tab and restart your debug session, is the 0x410 tab shown again?
Jiri
Hi, Jiri
At first, the program is stopped first break point - address 0x798.
I didn't set break point there. Screenshot is initial screen of debug session.
So, I think break point set automatically, that means program is ready to start running?
I don't understand clearly about your comment.
=> on 0x410 address is reset handler written in Assembly language. By default - first breakpoint is in main() function and as you can see on your screenshot - the program is stopped there - address 0x798.
And the 0x410 tab still show in my debug session.
Thank you
BR, minkyu.
Hope it helps.
Jiri
