Hi all,
I have to install the license offline. I get the activation.xml from my account -> licensing offline activation, and unfortunately during the installation in the java popup, the following message appears:"Invalid offline response, Response Type".
Is it a known issue ?
Pat
Hi Patrice,
We have just published hot fix that should fix the offline activation problem.
Could you possibly check this document: S32 Design Studio Offline activation issue hot fix
Hope it helps!
Stan
Hi Pat,
Thanks a lot for your notification.
We are currently experiencing some problems with activation code generation. (so the problem is not on your side)
Our licensing team is working on a fix.
I'll send out the official release announcement as soon as the problem is resolved (assume system is up and running in a day or so).
Thank you for your patience!
Stan
