Hi, dears:
I want to translate Green Hil's C project to S32 design Studio software for compilation, what do I need to do?
Solved! Go to Solution.
it looks like that you have your own isr vector table used together with default one (in MPC57xx__Interrupt_Init.c file). You can exclude from build the default one.
Jiri
After the program ported such an error, do you know what is wrong?
Wenhui Wang
Jiri
Before your reply to me, I added my source file to an MPC5744P project that can be compiled in the past, and I got such an error. What is the problem?
