"interrupt" not define as keyword w/ Codewarrior v11
759 次查看
zhangp973
seen as below
i call for an interrupt function of timer ,  but the interrupt was recognized as normal code rather than a keyword(like void, while).
in consequence, the build result  failed with "function has no prototype "
can anyone help , thx in advance
标记 (1)
720 次查看
stanish
This is caused by the compiler option - require prototype. I'd recommend you to declare ISR routine  prototype:
void interrupt Timer();
Hope it helps.
Stan
