I want to change my firmware from the MM9Z1J638 - Chip to the MM9Z1I638 chip.
Does somebody know points I have to change in the code? Where can i change the memory size?
Solved! Go to Solution.
Hi @Boris_Bloxsberg,
The difference is in the Flash size.
You can simply create a new project in CW 11.1 for the MM9Z1I638 part, copy your code and compile it.
Good idea, Thanks man!
Hi @danielmartynek ,
I`ve got an addtional question.
What I have to do if I want to change MM9Z1J638 Project to MM9Z1I638 Project?
Is it just a modification of the Linker file (*prm)? Or is there something more?
Hello @Boris_Bloxsberg,
Yes, it is just the linker file.
ROM = READ_ONLY 0xFE8000 TO 0xFFFDFF; // I
ROM = READ_ONLY 0xFE0000 TO 0xFFFDFF; // J
thx man
