I am not getting interrupt in input capture mode. I posted my code below , Please help someone
#pragma CODE_SEG __NEAR_SEG NON_BANKED
interrupt void IC0_ISR(void)
// new_capture = TC0; //save the value of input capture register
LCD_Cmd(0x80);
PORTA = 0xFF;
t[i]=TC0;
i++;
if(i==2) {
i=0;
// 6.0742270546073012209196379760675e-8
time_interval=(t[1]-t[0]);
time_period=(float)(0.0000256* time_interval);
frequency= 1/time_period;
sprintf(buffer,"%f",frequency);
for(j=0;j<4;j++)
LCD_Data(buffer[j]);
TFLG1 = 0x01; //clear interrupt flag
interrupt void TOI_ISR(void)
TFLG2 = 0x80; //clear interrupt flag
unsigned int TM;
/* User includes (#include below this line is not maintained by Processor Expert) */
void main(void)
/* Write your local variable definition here */
/*** Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/
PE_low_level_init();
/*** End of Processor Expert internal initialization. ***/
/* Write your code here */
LCDIni();
// LCD_Cmd(0x01);
LCD_Cmd(0x80);
LCD_Data('T');
PPST_PPST0 = 0; //set pull-up
PERT_PERT0 = 1; //enable pull-up
TSCR1 = 0xE7; //enable timer, stop timer during wait and freeze, disable fast flag clear
TIOS_IOS0 = 0; //channel 0 as an input capture
TCTL4 = 0x01; //capture on rising edge
TIE_C0I = 0x01; //enable interrupt on channel 1
TSCR2 = 0x80; //timer overflow interrupt enable, timer prescaler is 0
for(;;){}
/*** Processor Expert end of main routine. DON'T WRITE CODE BELOW!!! ***/
/*** Processor Expert end of main routine. DON'T MODIFY THIS CODE!!! ***/
} /*** End of main routine. DO NOT MODIFY THIS TEXT!!! ***/
sorry, i don't look on the data sheet, when you set TFLG2= 0x80 , it's only for timer over flow not for timer C01.
i mean the flag you must clear on initialise is TFLG1 = 0x01 and in your interrupt program too.
have you set the good vector adress in your project.prm file ?
there is a vector adress for C01 interrupt, and a vector adress for overflow interrupt .
as i look your program, you try to find a frequency, but if you take TC0 register i think you have 0 in return.
if you take TCNT you going to have a good value :
Tnew = TCNT;
Tperiod = Tnew - Told; (be careful to the carry)
Told = Tnew;
I have not set vector adress in your project.prm file. I do't now how to set it.
I clear this also TFLG1 = 0x01
I posted below my prm file . Help me in setting vector address
** THIS COMPONENT MODULE IS GENERATED BY THE TOOL. DO NOT MODIFY IT.
** Filename : Project_11.PRM
** Project : Project_11
** Processor : MC9S12XHZ512MAG
** Compiler : CodeWarrior HCS12X C Compiler
** Date/Time : 31/12/2014, 4:06 PM
** Abstract :
** This file is used by the linker. It describes files to be linked,
** memory ranges, stack size, etc. For detailed description of the PRM file
** see CodeWarrior documentation. This file is generated by default.
** You can switch off generation by setting the property
** "Generate PRM file = no" on the "Build options" tab in CPU component and then modify
** this file if needed.
** Copyright : 1997 - 2010 Freescale Semiconductor, Inc. All Rights Reserved.
** http : www.freescale.com
** mail : support@freescale.com
NAMES
END
SEGMENTS /* Here all RAM/ROM areas of the device are listed. Used in PLACEMENT below. */
RAM = READ_WRITE 0x2000 TO 0x3FFF;
ROM_C000 = READ_ONLY 0xC000 TO 0xFEFF;
PAGE_E0 = READ_ONLY 0xE08000 TO 0xE0BFFF;
PAGE_E1 = READ_ONLY 0xE18000 TO 0xE1BFFF;
PAGE_E2 = READ_ONLY 0xE28000 TO 0xE2BFFF;
PAGE_E3 = READ_ONLY 0xE38000 TO 0xE3BFFF;
PAGE_E4 = READ_ONLY 0xE48000 TO 0xE4BFFF;
PAGE_E5 = READ_ONLY 0xE58000 TO 0xE5BFFF;
PAGE_E6 = READ_ONLY 0xE68000 TO 0xE6BFFF;
PAGE_E7 = READ_ONLY 0xE78000 TO 0xE7BFFF;
PAGE_E8 = READ_ONLY 0xE88000 TO 0xE8BFFF;
PAGE_E9 = READ_ONLY 0xE98000 TO 0xE9BFFF;
PAGE_EA = READ_ONLY 0xEA8000 TO 0xEABFFF;
PAGE_EB = READ_ONLY 0xEB8000 TO 0xEBBFFF;
PAGE_EC = READ_ONLY 0xEC8000 TO 0xECBFFF;
PAGE_ED = READ_ONLY 0xED8000 TO 0xEDBFFF;
PAGE_EE = READ_ONLY 0xEE8000 TO 0xEEBFFF;
PAGE_EF = READ_ONLY 0xEF8000 TO 0xEFBFFF;
PAGE_F0 = READ_ONLY 0xF08000 TO 0xF0BFFF;
PAGE_F1 = READ_ONLY 0xF18000 TO 0xF1BFFF;
PAGE_F2 = READ_ONLY 0xF28000 TO 0xF2BFFF;
PAGE_F3 = READ_ONLY 0xF38000 TO 0xF3BFFF;
PAGE_F4 = READ_ONLY 0xF48000 TO 0xF4BFFF;
PAGE_F5 = READ_ONLY 0xF58000 TO 0xF5BFFF;
PAGE_F6 = READ_ONLY 0xF68000 TO 0xF6BFFF;
PAGE_F7 = READ_ONLY 0xF78000 TO 0xF7BFFF;
PAGE_F8 = READ_ONLY 0xF88000 TO 0xF8BFFF;
PAGE_F9 = READ_ONLY 0xF98000 TO 0xF9BFFF;
PAGE_FA = READ_ONLY 0xFA8000 TO 0xFABFFF;
PAGE_FB = READ_ONLY 0xFB8000 TO 0xFBBFFF;
PAGE_FC = READ_ONLY 0xFC8000 TO 0xFCBFFF;
PAGE_FE = READ_ONLY 0xFE8000 TO 0xFEBFFF;
END
PLACEMENT /* here all predefined and user segments are placed into the SEGMENTS defined above. */
_PRESTART, /* Used in HIWARE format: jump to _Startup at the code start */
STARTUP, /* startup data structures */
ROM_VAR, /* constant variables */
STRINGS, /* string literals */
NON_BANKED, /* runtime routines which must not be banked */
COPY INTO ROM_C000;
DEFAULT_ROM INTO PAGE_FE, PAGE_FC, PAGE_FB, PAGE_FA, PAGE_F9, PAGE_F8, PAGE_F7, PAGE_F6,
PAGE_F5, PAGE_F4, PAGE_F3, PAGE_F2, PAGE_F1, PAGE_F0, PAGE_EF, PAGE_EE,
PAGE_ED, PAGE_EC, PAGE_EB, PAGE_EA, PAGE_E9, PAGE_E8, PAGE_E7, PAGE_E6,
PAGE_E5, PAGE_E4, PAGE_E3, PAGE_E2, PAGE_E1, PAGE_E0;
DEFAULT_RAM /* all variables, the default RAM location */
INTO RAM;
END
INIT _EntryPoint /* The entry point of the application. This function is generated into the CPU module. */
STACKSIZE 0x0080 /* Size of the system stack. Value can be changed on the "Build options" tab */
By verifying on data sheet of the component you use, in the end of .prm file, you must add the vector adress of your program interrupt.
in your case, it's look like :
STACKSIZE 0x100 /* size of the stack (will be allocated in DEFAULT_RAM) */
/* use these definitions in plane of the vector table ('vectors') above */
VECTOR 0 _Startup /* reset vector: this is the default entry point for a C/C++ application. */
VECTOR ADDRESS 0xFFxx IC0_ISR //see on data sheet how is the vector adress for "input capture 0 interrupt" i.e. for HCS12XDP512, it's 0xFFEE
VECTOR ADDRESS 0xFFxx TOI_ISR //see on data sheet how is the vector adress for "overflow interrupt" i.e. for HCS12XDP512, it's 0xFF6F
