How do i active MCAT page
1,202 次查看
ahnjoseph
I had a EVMKit (MTRCKTBNZVM128 )
I did load S.W (FOC Sensorless) EVM Kit with Code warrior and Starting Program Freemaster
So I did well run motor on EVM-Kit.
But i didn`t find MCAT Page
912 次查看
RadekS
Hi Ahn,
Please download attached MC9S12ZVML128_PMSM_Sensorless project with integrated MCAT tool.
This project should fits to standard LINIX motor delivered with MTRCKTSPNZVM128 kit.
Note: We know about some issues with specific motors and sensorless methods. If you will have any problem with motor driving, please try commenting out next two lines in stateRun() function:
if(pos_mode!=force)
AND
ACLIB_PMSMBemfObsrvDQ_Clear(&drvFOC.pospeSensorless.bEMFObs);
I hope it helps you.
RadekS
UPDATE: I have to draw down this unofficial example code. Official releases will be available at:
Automotive Motor Control Development Solution|NXP
4 回复数
913 次查看
RadekS
Hi Ahn,
if(pos_mode!=force)
AND
RadekS
912 次查看
Luke_Chun
Hello RadekS
I found your answer(this ticket) about MCAT using S12ZVM.
However I could not find the attached code that was related with MCAT.(you removed that code....)
And as AN5135, it shows MCAT for PMSM using S12ZVM.
However AN5135SW did not contain the MCAT application…
Could you check this reason?
Because my customer asked same thing, the wish to use MCAT but they could not find MCAT using S12ZVM…
Thank you.
912 次查看
RadekS
Hi Kwangsu,
The original S12ZVM PMSM software used excel file for header file generation.
The version with MCAT was released later.
As I wrote, please go to http://www.nxp.com/products/software-and-tools/run-time-software/automotive-software-and-tools/motor...
After that please click on “MTRCKTSPNZVM128: 3-phase Sensorless PMSM Development Kit with S12 MagniV MC9S12ZVML128 MCU” motor control kit link.
The appropriate design documents and software might be downloaded when you unfold this list under “More” link like on picture below:
I just downloaded MTRCKTSPNZVM128 Software and check that it contains MCAT as part of FreeMaster project.
Radek
912 次查看
ahnjoseph
Thank you
Your mention is useful for me
But I can`t run a Freemaster
When the Freemaster file click then  show below box
Can help me?
