Changing the bootloader.
904件の閲覧回数
carleslloret
I just throw a question to the air... Is it possible to update the bootloader with a user application firmware? The user application user certainly can be updated with a bootloader... but it is possible to do the same with the bootloader?
The bootloader simply erases and saves some values into the eeprom . Is it possible to do the other way around?
Thank a lot.
3 返答(返信)
744件の閲覧回数
carleslloret
What MCU do you use?
Did you consider the option of two bootloaders?
mc9s12xs128.
744件の閲覧回数
dianabatrlova
Thank you for the details.
You can use CodeWarrior IDE and via BDM interface load the new bootloader into MCU.
Some possibilities how to update a bootloader can be found on the community thread below:
how could I update bootloader via bootloader?(s12xe)
If you have an interest in the bootloader example for the S12X devices see below:
http://www.nxp.com/files/microcontrollers/doc/app_note/AN4258SW.zip
SW:
https://www.nxp.com/files-static/microcontrollers/doc/app_note/AN4258.pdf
I hope it helps.
Diana
744件の閲覧回数
dianabatrlova
Hello Carles,
The link below can be useful:
Simple Serial Bootloader for S12Z - AN draft
I hope it helps.
Diana
