Solved! Go to Solution.
Is USB Serial converter support enabled in kernel menu for your board?
For example see attached snapshot from LSDK 1809 kernel menu.
This menu is available using the following in kernel menu:
Device Drivers --->
[*] USB support --->
<*> USB Serial Converter support --->
Pavel Chubakov
Device Drivers --->
Pavel Chubakov
Hi Pavel, Thank you so much, I will check and let you know later.
