Network Connection in Ubuntu rootfs LS1028ARDB
1,504件の閲覧回数
anesarkar
    I am getting the following error after I build the ubuntu image on SD card and boot it on LS1028ARDB.
After I log into emergency mode, I am not able to connect to any network. Is the error because the image was not built correctly?
タグ(2)
5 返答(返信)
1,333件の閲覧回数
yipingwang
Hello Anish Nesarkar,
Please try the ubuntu rootfs filesystem built from BSP 0.3 release, I uploaded it as the following.
https://drive.google.com/open?id=1ZrP4maZccROaWCfXFFUkjRjGOFpG99FX
Please refer to my Linux booting up log in the attachment.
Yiping
1,333件の閲覧回数
anesarkar
    I followed these steps:
1. flex-installer -b bootpartition_arm64_lts_4.14.tgz -r build/images/rootfs_ubuntu_bionic_arm64.tgz -f firmware_ls1028ardb_uboot_sdboot.img -d /dev/sdX
2. Stopped at boot menu
   a. tftp 0xa0000000 wyp/ls1028ardb/Image
   -> error: serverip not set
   b. setenv serverip 192.168.2.1
   -> error: ipaddr not set
   c. dhcp
Any suggestions?
1,333件の閲覧回数
yipingwang
Please use the following commands to boot up the system.
=> setenv bootargs "console=ttyS0,115200 root=/dev/mmcblk0p3 rw rootwait earlycon=uart8250,mmio,0x21c0500"
=> ext2load mmc 0:2 0xa0000000 /Image
=> ext2load mmc 0:2 0xb0000000 /fsl-ls1028a-rdb.dtb
=> booti 0xa0000000 - 0xb0000000
Yiping
1,333件の閲覧回数
anesarkar
I don't understand where is the issue.
1,333件の閲覧回数
yipingwang
Please deploy Ubuntu rootfs in partition mmcblk0p3 of the SD card, please make sure your SD card is large enough.
