Is there a guide of how to connect the SPIGEN to any of the PT200x evaluation boards? What to with IRQB, DRVEN, RESETB, DBG?
Merry Christmas and Happy New Year
Solved! Go to Solution.
Dear Richard,
thank you for confirmation of your EVB.
Then please follow section 7. in the FRDMPKPT2000EVM evaluation board User Guide attached for both software and hardware configuration.
The User Guides are old and some of the links do not work anymore.
The SPIGen software you can download from this link.
The PT2000 SPIGen configuration file from this link.
The PEmicro for the FRDM-KL25Z EVB works correctly.
With Best Regards,
Jozef
Thanks again Jozef. I have I have FRDMPKPT2000EVB hardware is that valid for KTPT2000FRDM3CUG documentation?
Dear Richard,
With Best Regards,
Jozef
OK Jozef, that avoids the wiring issue, however how do I get the SPIGEN software to work with FRDM-KL25Z MCU EVB?
Dear Richard,
for this please refer to the section 5. in the KTPT2000FRDM3C User Guide. There is a detailed description how to use the EVB with the SPIgen software.
With Best Regards,
Jozef
Dear Richard,
Happy New 2024 Year. Yes, we have such documents. For recommended connections of the mentioned pins, please refer to our EVBs User Guides. E.g. to KITPT2000FRDM3C User Guide or to KITPT2000FRDM6C User Guide + to FRDM-KL25Z MCU EVB.
With Best Regards,
Jozef
