FS85: About MCU fault recovery strategy
682件の閲覧回数
Kojimaa
Hi NXP,
  What I want to know about this strategy is whether FS0B automatically becomes high after meeting the recovery conditions, or does it need to be released again via software ?
Thank you  in advance
タグ(1)
3 返答(返信)
676件の閲覧回数
guoweisun
When the fail-safe outputs FS0B is asserted low by the device due to a fault, the exit
conditions must be validated before allowing these pins to be released.
These conditions are:
  • Fault is removed
  • LBIST_OK = ABIST1_OK = ABIST2_OK = 1
  • Fault Error Counter = 0
  • RELEASE_FS0B register filled with ongoing WD_SEED reversed and complemented
664件の閲覧回数
Kojimaa
    Do I also need to release FS0B again via software after FCCU recovered during the recovery window?
648件の閲覧回数
guoweisun
For the SBC side to release FS0B:
  • Fault is removed
Firstly fault should be removed, then read the related registers to make sure LBIST_OK = ABIST1_OK = ABIST2_OK = 1 and Fault error counter=0 then fill the RELEASE_FS0B registers to release FS0B.
