I'm trying to set timing parameters for a Nor Flash working on the GPCM mode on a P2020 board.The LALE timing can be set by OR[EAD] and LCRR[EADC] per P2020RM:
EAD: External address latch delay. Allow extra bus clock cycles when using external address latch (LALE).
0 No additional bus clock cycles (LALE asserted for one bus clock cycle only)
1 Extra bus clock cycles are added (LALE is asserted for the number of bus clock cycles specified by LCRR[EADC]).
But I did not find any rule or guide on how to set the timing for LALE. Can you give me some suggestion?
Thanks in advance.
Please refer the P2020 QorIQ Integrated Processor Reference Manual, 12.4.1.2 External address latch enable signal (LALE).
> I did not find the the minimal required LALE pulse duration and the minimal required hold time
> in the Micron's Nor Flash datasheet.
Please request clarification from the Micron technical support.
Thanks for your suggestion.
