As per AN11802 rev1.8 instructions, sw369328.zip was applied to raspberry pi 5, but the following error occurs.
DiscoveryLoop Example:
Line: 133 Error - (0xF181) has occurred : 0xCCEE CC-Component ID, EE-Error code. Refer-ph_Status.h
Line: 142 Error - (0xF181) has occurred in NFCLIB
By any chance, isn't it a KERNEL SPI CFG DIR problem? Or is there a problem with SPI setting?
Solved! Go to Solution.
I solved it.
Board_PiPn5180.h
#define PHDRIVER_LINUX_USER_SPI
/*#define PHDRIVER_LINUX_KERNEL_SPI*/
I solved it.
Board_PiPn5180.h
Thanks for your sharing.
