Why no timestamp in the META frame of SJA1105
BravoEven
Hello:
   I want to know why no timestamp int the follow meta freme in the example figure shown belong?
 I have config the SEND_META[0/1] set int the General Parameters table, but there is still Zeros in the frame. By the way , the structure of META frame seems not fit with the UM11040
PetrS
could you please share switch configuration you have?
BR, Petr
BravoEven
are the "21 d9 1b c2 " is the timestamp Lower part? I want to confirm ,thanks!
PetrS
BR, Petr
