Can we use 2 x CD1020 and 1 x CD1030 in daisy chain SPI configuration?
Thanks a lot.
Solved! Go to Solution.
Your patience is greatly appreciated.
Please review the response from our specialist below:
Yes, CD1020 and CD1030 daisy chain are compatible.
Customer can use 2 x CD1020 and 1 x CD1030 in daisy chain SPI configuration.
I hope this information helps.
David
David
Hi David,
Thanks a lot for clarifying. I informed the customer.
I hope all is great with you. Thank you for using the NXP communities.
I want to let you know that I am working on your request. As soon as I get a response, I will let you know immediately.
I will appreciate your patience.
David
