What is the gold thickness of PN MPXM2202A terminal/lead?
1,098件の閲覧回数
matthew_carmich
https://www.nxp.com/docs/en/data-sheet/MPX2202.pdf
I am trying to identify the gold thickness of the terminals, but it is not located on the datasheet.
タグ(1)
5 返答(返信)
1,007件の閲覧回数
lisettelozano
Hello Matthew,
We have the material declaration for the sensor here https://www.nxp.com/mcds/MPXM2202A.pdf
Please let me know if this helps.
Paulina
1,007件の閲覧回数
matthew_carmich
Is the plating on the leads a part of the Copper Lead Frame section of materials?pastedImage_1.png
1,007件の閲覧回数
matthew_carmich
The reasoning behind this request is for gold embrittlement concerns if the parts do not have the gold plating removed.
1,007件の閲覧回数
lisettelozano
Hello Matthew,
Following your inquiry, I just received a response internally.
The MPXM2202A uses a pre-plated Lead Frame. The pre-plating material is NiPdAu (Nickel, Palladium, Gold), which substances are listed under the Copper Lead Frame material in the material declaration.
I hope this information can be helpful and we appreciate your patience.
Paulina
1,007件の閲覧回数
lisettelozano
Hello Matthew,
I requested assistance internally in order to provide an accurate answer. I'll get back to you as soon as possible. Thank you for your patience.
Paulina
